Hi,
There is a few seals on these gearboxes, one for each driveshaft, one for the input shaft and small gaskets on boot holes and selector shaft.
More than likely it will be driveshaft seal as these are the most common to go, you will have to wash the the box down and monitor where the oil comes from.
If it's a driveshaft seal then you wont need to remove the box, just drain the oil and remove whatever shaft it's leaking from.
If you are in need of seals I sell them in my online shop, just follow the link in my sig
Hope this helps
Gary
This is true, crank shaft rear oil seal can cause this aswell but as the guy has identified the oil as gearbox I took it that the engine seals were ok,
If it's leaking between the box and engine you may need to take the box out and have a look to see where it's comings from
Gary
