A little question for people who might know.
The system I have on my 94 gt is superb, sounds the bollocks, no problems with it.
The only issue is that the box/hanger (might be a mixture of both) sometimes rub on the rear metal on the back of the car. Sometimes it does not do it but when it warms up it does move a little due to the roads and stiff suspension.
Its annoying the squeaky noise that it makes so my question is this.
Is there a soft no flamable material you could put on the edges of the metal (not on the box itsself) such as really thick rubber to eleminate the sound of the metal knocking together?
  • 4 years later...
heat wrap would work for a while but it would eventually ware away, just go to a local exhaust fabricator and the should be able to sort it for under 50 quid
