Speedo has stopped working the other day, taken the connector off the gearbox and the spindle has sheered off, pain in the ass!
When i start the car no engine management light, when i drive and get to around 50-60mph it then turns on and stays on. However once i turn the ignition off and back on the engine light doesnt come back on.
Can the car sense if its disconnected? only reason i am unsure as im missing one of the sensor plugs on my water temp so no sure which ones causing it!!
