mckewan Posted July 5, 2011 Share Posted July 5, 2011 hi need abit of info on my brakes my handbrake light comes on when i give the brakes a firm press I've checked the level and seems fine the abs is working. I've looked at the handbrake swith and this is working im puzzeld any one can shed abit of light on this one cheers Quote Link to post Share on other sites
akyakapotter Posted July 5, 2011 Share Posted July 5, 2011 I'm not sure has haven't looked at these yet maybe they have brake pad wear indercators maybe up pads are low Quote Link to post Share on other sites
hill_bill10 Posted July 6, 2011 Share Posted July 6, 2011 fyi, the handbrake light as you call it isnt actually a handbrake light, its a brake warning light Quote Link to post Share on other sites
aidanep71 Posted July 6, 2011 Share Posted July 6, 2011 ya it tells ya either your nearly out of brake fluid or your handbrake is pulled..try put a bit of fluid in it may not seem low but when ya press the brakes the level will drop slightly Quote Link to post Share on other sites
mckewan Posted July 13, 2011 Author Share Posted July 13, 2011 ya it tells ya either your nearly out of brake fluid or your handbrake is pulled..try put a bit of fluid in it may not seem low but when ya press the brakes the level will drop slightlythe fluid level is ok think im going to take a look at the pads its still flikering could it be a faulty wire mite sound daft ? Quote Link to post Share on other sites
