TrisK Posted July 11, 2011 Posted July 11, 2011 is the correct set upcatch can has 2 ports1 -> rocker cover2 -> breather filter to atmosif is has 3 ports1-> rocker2 -> inlet3 -> breather filter to atmosthanks Quote
nastyrash 2003 Posted July 11, 2011 Posted July 11, 2011 is the correct set upcatch can has 2 ports1 -> rocker cover2 -> breather filter to atmosif is has 3 ports1-> rocker2 -> inlet3 -> breather filter to atmosthankshello, no mate never to atmospher if u want to keep engine breathing. look up on my posts u will find a topic on cans think liamd posted it up and thr are diagrams done by enzo1234, and that is the system u want to use mate. Quote
TrisK Posted July 11, 2011 Author Posted July 11, 2011 so this diagram is correct?I have a relocated airfilter, so i dont have a feed back into the efi pipe, any suggestions on another way to still have it connect correctly? apart from get a silicon thing with a nipple or drill into the alloy pipe? Quote
