TrisK Posted July 11, 2011 Share Posted July 11, 2011 is the correct set upcatch can has 2 ports1 -> rocker cover2 -> breather filter to atmosif is has 3 ports1-> rocker2 -> inlet3 -> breather filter to atmosthanks Quote Link to post Share on other sites
nastyrash 2003 Posted July 11, 2011 Share Posted July 11, 2011 TrisK said: is the correct set upcatch can has 2 ports1 -> rocker cover2 -> breather filter to atmosif is has 3 ports1-> rocker2 -> inlet3 -> breather filter to atmosthankshello, no mate never to atmospher if u want to keep engine breathing. look up on my posts u will find a topic on cans think liamd posted it up and thr are diagrams done by enzo1234, and that is the system u want to use mate. Quote Link to post Share on other sites
TrisK Posted July 11, 2011 Author Share Posted July 11, 2011 so this diagram is correct?I have a relocated airfilter, so i dont have a feed back into the efi pipe, any suggestions on another way to still have it connect correctly? apart from get a silicon thing with a nipple or drill into the alloy pipe? Quote Link to post Share on other sites
TrisK Posted July 12, 2011 Author Share Posted July 12, 2011 bump Quote Link to post Share on other sites
