hello
right i set my actuator at 1 bar
but i only seem to be getting 0.8/0.75 bar on my gauge.
The car feels quick
but seems to be a good kick of boost then backs off
Could this be my turbo?
or a leak?
or my actuator(hks)?
when fitting the HKS it felt tight and not loose?
any ideas?
CT9 turbo
Adjust the actuator again and then see if you can hit 1 bar - assuming you have got other supporting mods (fuelling something to remove fuel cut etc?)
all supporting mods,
fmic
blitz decat & exhaust
hks actuator
ported manifold and turbo
relocated filter
JAM ecu
What is standard boost in bar?
do the ct9s seem to back off at the top end of revs?
prob get a ebc and have ya actuator set at like .6. thats how i ran my hybrid set up. then controllers doin all the work and ya actuator will hold boost better.
it only backs off slightly at higher revs.(not at 3.5K)
theres no leaks as i carnt feel anything(hipefully)
would it be a good idea to me to get a MBC or EBC and up the boost from that?
or adjust actautor at 1 bar?
try actuator but most people use a boost controller over .8 i think. also the ct9 will run out of puff high end.
Thanks dude. Reset actuator. Was set at 124mm opps
Now at 121/120 :lol:
