No boost. 0.2 bar. No lights help
New. Update. After post 3
Actuator was stuck open.
I've undo it. Went for a quick test. And I can now get one green boost light but nothing more.
Not alot of turbo pressure there at all
Carnt find any leaks.
Could this be the actuator not holding flap down?
Any other ideas?
Hello again lol
Right stuck my stock actuator back on
Went for a drive.
Hit boost. Went to 1 bar n went pop
No boost. Engine management light came on n went off again.
But no whistling like a leak.
It boosts as 0.2 bar so slow lol n only seems to come in at higher revs
No leaks as I took the piping off and can feel turbo pressure under revs. Not on idle
No oil in ic piping
N no whistling.
Dv works as I can see it going in and out.
Ideas?
Stock actuator is on
Vac hose from actuator to turbo.
And the spare one on actuator at back is blocked off!
Nope.
Yes actuator is on.
Had to put a bolt and 2 nuts on but yes attached
Vac lines on back inlet. Turbo checked
No exhaust leaks
No intercooler leaks. Could it be the wastegate flap came off?
standard actuator wouldnt boost at bar
i would have guessed that it wasnt connected, didnt open the wastegate, so the turbo boosted freely
then maybe it cracked the wastegate udner the pressure (or made the crack bigger(all ct9s have them))
now its leaking boot from the wastegate?
just a theory
The second port on the stock actuator should be connectod to the hi/lo solenoid or a boost controller otherwise it will run the base setting of the stock actuator - since its old and weak it could well be 0.2bar.
I would fit the HKS and set it up properly at 0.8bar doing the runs in 4th gear and use a bit of trial and error to set the length. One main thing though - take it easy when doing it! There's no need to just hammer the throttle every time, ease the boost up to see where it settles so you don't hit fuel cut all the time!
The HKS will hold boost better if setup properly.
Ive got a jam ecu buddy!
No high lo solenoid attached!
I've done a few figures from hks
Just measured 128mm at 0.5/0.6 bar
So going to 126mm should be 0.7/0.8
I had 123mm at 1.1 bar.
This in second gear n first gear launches. Due to my drive being not that big lol
Do it in 4th, if you set it up in the lower gears it will sit higher in 4th/5th.
The JAM ecu may only have raised the fuel cut level slightly, the pop and engine management light coming on like you describe is what fuel cut does. Also the JAM ecu won't do anything to effect the boost level.
Just find a nice long quiet piece of road and have a play there to set up the HKS. :o
Reset again!
Now at 0.65 bar lol in first and 0.7 in second.
Going to buy a ebc and control it from that! Would that be my best decision?
I carnt as I'm not insured hense the driveway driving lol
Cheers your for help dude.
Are the blitz Dual sbc any good?
Easy to wire in?
