Heard you need to remove the oil return pipe and watch for oil out the bottom of the turbo when priming. Will oil not come out from the sump up the oil return pipe when the car has been refilled? Matt
I'd take the return pipe off. Believe the oil warning light isn't a accurate thing to use. No it doesn't come out the sump. Hope that helps
No mate it wont, the sump is lower than the turbo, just leave your return pipe connected to the sump an remove from the turbo, take the king lead off and get someone to turn your motor over whilst you look for oil :)
John
