what do you do with the small pipe that normally goes to the efi pipe after the efi pipe is removed.where do i tee it in? cheers
that goes to the rocker cover? or that goes to the dumpvalve?
neither its next to the old dump valve on on efi pipe, it then goes to a metal pipe which i think goes to the actuator.still boosts so dont see what its for
did you have the boost restrictor still pumbed in?
nope. at the top of the efi pipe just to the left of the standard re circ there is a small pipe
If you have the stock boost controller plumbed in leave it venting to atmosphere or you end up in lo boost all the time. If not just remove it / loop it / block it off, it doesnt really matter.
