mattyD Posted September 15, 2011 Posted September 15, 2011 having gone through 2 winters without heaters, i am going to get them done before the cold sets in this year, but i have a problem with the drivers side vent in that no air comes out of it :s on a little inspection, i found that nothing is connected to it so obviously the air cant travel out! does anyone know what i need for it to work? Quote
lukEp Posted September 15, 2011 Posted September 15, 2011 There a tube which runs from the center console behind the knee panel under te steering wheel which feed the air check if it's there or popped off Quote
mattyD Posted September 15, 2011 Author Posted September 15, 2011 There a tube which runs from the center console behind the knee panel under te steering wheel which feed the air check if it's there or popped offok mate, i have a feeling for some reason it may not be there! but will have a check if its not there are they relitavely easy to get hold of? Quote
lukEp Posted September 15, 2011 Posted September 15, 2011 Never known anyone that's needed one but can only expect the na ones are the same so off to the breakers for you lol Quote
mattyD Posted September 15, 2011 Author Posted September 15, 2011 Never known anyone that's needed one but can only expect the na ones are the same so off to the breakers for you lolhaha, great! theres a first time for everything and as per usual its always me booooooooooo! thanks for the help mate Quote
