Whitecurrant Posted September 18, 2011 Posted September 18, 2011 Hi, Can anyone tell me what size the gearbox bolts are and where i can get a threaded bar of the bolt size as its a fine thread and i cant find any. So i can attach the engine to the stand.Thanks James Quote
sam2kk8 Posted September 18, 2011 Posted September 18, 2011 onto the block? there 17s and a couple of 14s Quote
Whitecurrant Posted September 18, 2011 Author Posted September 18, 2011 onto the block? there 17s and a couple of 14sYea thanks mate but du you know where to get the fine threaded bolts as there not normal thread Quote
sam2kk8 Posted September 18, 2011 Posted September 18, 2011 ooh suppose you can just buy some off someone breaking their car? as they'd probley just bung them away somewhere! Quote
rorenapier Posted September 18, 2011 Posted September 18, 2011 Cut the legs down on the bracket from the stand, then use your gear box bolts. Quote
Whitecurrant Posted September 18, 2011 Author Posted September 18, 2011 Cut the legs down on the bracket from the stand, then use your gear box bolts.I was thinking that but its not my engine stand.Any chance you still have the 17mm bolts sam Quote
sam2kk8 Posted September 19, 2011 Posted September 19, 2011 no sorry pal, im in need of 1 too!Just message a few people breaking Quote
Bean Posted September 19, 2011 Posted September 19, 2011 get some from any place that sells bolts local too you, like an iron mongers ect. or ebay has every size of bolt ever made. Quote
ryan lang Posted September 19, 2011 Posted September 19, 2011 the bolt in the end of the fuel rail is the same thread, i took that to my local hardware place and asked for it in a certain length and the brought them out also get some big washers too Quote
Whitecurrant Posted September 19, 2011 Author Posted September 19, 2011 Got permision from the stand owner to cut the legs down problem solved thanks anyways Quote
