akyakapotter Posted September 26, 2011 Posted September 26, 2011 where can i splice in to with the orange wire so it dims orange at night its bright white at the moment and dose my head in pic would be very helpfull thanks in advance Quote
MARC MOSS Posted September 26, 2011 Posted September 26, 2011 I'm assuming the orange needs a +ve feed to enable it to dim yeah??If so take it from a dash light feed dude so it dims when u put your lights on Quote
akyakapotter Posted September 26, 2011 Author Posted September 26, 2011 i think so mate was driving in rain last night and couldnt see anything cause its briht white just need to no what wire to tap in to and where Quote
Amjad Posted September 26, 2011 Posted September 26, 2011 Wired my gauges to hazard switch iirc Quote
MARC MOSS Posted September 26, 2011 Posted September 26, 2011 Does your hazard switch light up when u switch your lights on then? Quote
akyakapotter Posted September 26, 2011 Author Posted September 26, 2011 im not sure ill go have a look 2secs Quote
akyakapotter Posted September 26, 2011 Author Posted September 26, 2011 yes it dose light up mate Quote
MARC MOSS Posted September 26, 2011 Posted September 26, 2011 Just looked at the wiring diagram and it'll be fine to feed it from the hazard light illumination +veYou now just need to remove the switch and use a Meter to determine which wire gies live when u switch on the lights, splice into that and it'll work fine Quote
akyakapotter Posted September 26, 2011 Author Posted September 26, 2011 been trying it it dose nothing just stays white may just have to get a dimmer swich and do it that way Quote
CLARKYTRD Posted September 26, 2011 Posted September 26, 2011 There is a spare connector under the steering wheel, its on the right hand side.Wire it into that, I'm doing mine today. I just need to find out which wires are what.I'l try put up pics if I find out what wires are what ok! Quote
MARC MOSS Posted September 26, 2011 Posted September 26, 2011 been trying it it dose nothing just stays white may just have to get a dimmer swich and do it that wayare you sure its definately live dude? try running a live from the battery and see if that works, have u tried also removing the other live which powers the white bulb when attaching this other cable? Quote
akyakapotter Posted September 26, 2011 Author Posted September 26, 2011 ive had it so if i turn the lights on the gauge lights up and if the lights are off its not lit up with them connected so when i turn the light on it dims a tiny bit i mean may as well not bother doing it way to bright to see where im going at night lol carkytrd yeah take pic please mate :-D Quote
