While were on topic, would anyone think heat range 7 NGK iridiums are to high for 1 bar of boost on a CT9 with a plug and play ecu?
Also anyone know what to gap them at? I think mine are currently 0.9mm
Cheers
Luke
Cheers
Luke
Dont you want to be going for a heat range 6? Maybe 5? I gap mine at 0.9
D
i thought the higher modded your engine the higher the heat range?
a standard 4efte - heat range 6
a lightly modded 4e - heat range 7
heavily modded 4e - heat range 8/9?
or is this wrong?
or is this wrong?
I'm only going on what i've been told, dependent on manufacturer, the heat range merely relates to the optimum operating and self cleaning properties of a plug. So dependent on the state of tune, a higher power engine will of course create more heat, warranting a 'hotter' plug. A colder plug would merely overheat and fail, a too hotter plug will foul up and limit its performance. The heat range doesnt have anything to do with the temperature of the spark/ignition itself. Certain manufacturers work their heat range scale differently to others. NGK's works out the lower the number, the higher the operating temp.
Heres a link from NGK's own website to verify. Well worth a read:)
NGK
D
Cheers
Luke
I've got the same and basically same spec :mellow:
Ok cheers guys, was just thinking that maybe my plugs were the cause of this hesitation.
Was going to maybe change my gap from 0.9 to 0.8 but I doubt it will make any difference.
