QUADLIGHT GT Posted October 13, 2011 Posted October 13, 2011 as above i've removed standard front wishbone bushes.. as i'm fitting poly-bushesquestion is how do i remove inner front metal tube as that also has a small lip rubber on it too ???, as i will be having these wishbones powder-coated which will go in a very hot oven to bake so dont want to ruin anything..i'm sure some people on here hav had thres powdercoated wht did u do ?Thanks! Quote
Amjad Posted October 13, 2011 Posted October 13, 2011 If it's the ALK one (rear?), I cut through it with a grinder Quote
Asad Posted October 13, 2011 Posted October 13, 2011 ^ as above Cut it then whack it with a hammer to loosen it you'll see like a crack appear along where you've made the cut Quote
rorenapier Posted October 13, 2011 Posted October 13, 2011 If your reffering to the main bush on the wishbone, then use a hack saw, put a cut in it and pop it out.... Quote
QUADLIGHT GT Posted October 13, 2011 Author Posted October 13, 2011 thnks for your comments my bad.. i'm actually referring to the both wishbone bushes actually..ive had the both bushes removed from a garagebushes removed- now i jus need to know if i pop the front bush ring out to remove the (thin rubber with ring around it)will i need to reuse this again after i have the wishbones powder-coated ??or can i buy some new ones from ?? Thanks! Quote
Asad Posted October 14, 2011 Posted October 14, 2011 You can get rid of it all, EXCEPT the round/halfmoon shaped washer for the rear of the wishbone you will need this when putting the antilift kit on....assuming you are? Quote
QUADLIGHT GT Posted October 14, 2011 Author Posted October 14, 2011 <br />You can get rid of it all, EXCEPT the round/halfmoon shaped washer for the rear of the wishbone you will need this when putting the antilift kit on....assuming you are?<br /><br /><br /><br />Ok sounds straight foward then.. BUt i wont be usung a "lift kit" Basically i'm upgrading to poly bushes onlyThanks bro Quote
Asad Posted October 14, 2011 Posted October 14, 2011 ahh then in that case i hope you havent cut off the rear crush tube iirc you still need it....along with the round/halfmoon washer Quote
QUADLIGHT GT Posted October 14, 2011 Author Posted October 14, 2011 ahh then in that case i hope you havent cut off the rear crush tube iirc you still need it....along with the round/halfmoon washeroh.. think i'l leave the rear crush tube on there n only remove the half moon washerthen get the wishbones powder-coated ? Thanks for the advice bro..appreciated Quote
Asad Posted October 14, 2011 Posted October 14, 2011 yeah you can remove all of the front one (cylinder bush) and keep the crush tube on and the washers in a safe place....ask them not to coat the crush tube tho seems best if you dont and your good to go Quote
QUADLIGHT GT Posted October 15, 2011 Author Posted October 15, 2011 yeah you can remove all of the front one (cylinder bush) and keep the crush tube on and the washers in a safe place....ask them not to coat the crush tube tho seems best if you dont and your good to go[/quotewicked! Nice one bro... Quote
