wishbone bushes removed
as above i've removed standard front wishbone bushes.. as i'm fitting poly-bushes
question is how do i remove inner front metal tube as that also has a small lip rubber on it too ???
, as i will be having these wishbones powder-coated which will go in a very hot oven to bake so dont want to ruin anything..
i'm sure some people on here hav had thres powdercoated wht did u do ?
Thanks! :)
thnks for your comments :)
my bad.. i'm actually referring to the both wishbone bushes actually..
ive had the both bushes removed from a garage
bushes removed- now i jus need to know if i pop the front bush ring out to remove the (thin rubber with ring around it)
will i need to reuse this again after i have the wishbones powder-coated ??
or can i buy some new ones from ??
Thanks!
  Asad_EP5DR said:
<br />You can get rid of it all, EXCEPT the round/halfmoon shaped washer for the rear of the wishbone you will need this when putting the antilift kit on....assuming you are?<br />
<br /><br /><br />
Ok sounds straight foward then..
BUt i wont be usung a "lift kit"
Basically i'm upgrading to poly bushes only
Thanks bro :)
  Asad_EP5DR said:
ahh then in that case i hope you havent cut off the rear crush tube iirc you still need it....along with the round/halfmoon washer
oh.. think i'l leave the rear crush tube on there n only remove the half moon washer
then get the wishbones powder-coated ?
Thanks for the advice bro..
appreciated :)
yeah you can remove all of the front one (cylinder bush) and keep the crush tube on and the washers in a safe place....ask them not to coat the crush tube tho seems best if you dont and your good to go
