You can indeed :) I personally wouldn't go over 1bar though and at that pressure you could see upto 220bhp+ People have ran higher boost levels than this but if your planning on doing this i'd make sure you have a healthy engine and get everything set up the best it can be.
the engine will be rebuild with oem spec parts... but glad i can run a td04 without to much modifications
Mine makes 201bhp TD04L with the stock ecu at 0.86bar :) with supporting fueling mods, i reckon i could get another 25-30hp if i changed the ecu.
How longs a piece of string ....
Most dont do over a bar (220ish) some "braver" people do 1.2 (203/40ish)
Personally i run 1.5 (270/60ish estimated) on a standard engine that had over 200'000km on it without even dropping the sump, Did that for over 18 month without a single problem on pump fuel.
