hi everyone,
think i sould get down to the problem.
rite im basicaly in the middle of an engine rebuild and im fitting a thicker head gasket, regrinding the crank the full shabang.
the problem i got is the head bolts.
i want to uprate the head bolts but dont want to tap and die the block and heads and dont want to spend stupid money.
can you suggest what head bolts and where i can get them from (website would be easyer).
or would i be better off getting standard toyota head bolts bearing in mind im going to be running high ish boostage.
any advise would be greatful
if your looking to run high boost i would use arp head studs rather than arp head bolts as they alot more reliable for higher boost levels,
are they not from a 4age though and dont fit straight into the block or head and therefor require machining.
I have them and im gonna need the block drilled and the holes in the head made a fraction wider.
