indicators stopped working?
got in my car this morning, went to indicate out of my road and nothing? the hazard button works and all corners come on but when i use the indicator stalk nothing happens?
any help will be massively appreciated!
thanks
quick update....just went and tried my indicators and they worked??? they worked after i pressed the hazard button? ive checked the fuses in the engine bay and all seems good unless its a relay gone? if this is the case could someone help me find the correct fuse/relay that might be at fault? :)
quick update....just went and tried my indicators and they worked??? they worked after i pressed the hazard button? ive checked the fuses in the engine bay and all seems good unless its a relay gone? if this is the case could someone help me find the correct fuse/relay that might be at fault? <_<
Common fault, I was caught out by it and its when the hazard light button hasn't fully returned, therefore bypassing the indicators because it still thinks the hazards are on.
Jamie
  • 6 months later...
  • 2 months later...
