tom_1593 Posted October 25, 2011 Posted October 25, 2011 If the oil seals in the turbo are jiggered would that eventually mean the turbo starts to lose boost? My boost has dropped but still holds it, Just doesnt reach what it is ment to. Quote
corofin12345 Posted October 25, 2011 Posted October 25, 2011 If the oil seals in the turbo are jiggered would that eventually mean the turbo starts to lose boost? My boost has dropped but still holds it, Just doesnt reach what it is ment to.if the seals were going ud be burning oil mate plus a turbo will boost away even if the seals are going.. what actuator do you have on there? Quote
H_D Posted October 25, 2011 Posted October 25, 2011 check for boost leaks 1st...make sure all your vacume hoses are ok and not split,also check yor intercooler piping joins and make sure the jubli clips or clamps are tightened properly, Quote
conz1 Posted October 25, 2011 Posted October 25, 2011 i had a little problem when boosting and i changed all my old jubili clips with better newer ones and it stopped it playing up. so like above ^ check all of your piping and clips man Quote
