I FIND IF I LEAVE MY CAR TO WARM UP FOR SAY 10 MINS IN A MORNING AND THEN DRIVE OFF BOOST FOR A FURTHER TEN MINS THE GAUGE IS STILL NEAR COLD.....HOWEVER MY MECHANIC SAYS HE DOESNT THINK ITS THE THERMOSTAT AS IF ITS LEFT RUNNING FORA WHILE WITH NO HEATER ON IT DOES RISE TO APPROX HALFWAY....IS THIS NORMAL OR IS IT THE USUAL STAT PROBLEM OR WHAT?by the way SORRY FOR CAPS ITS MY PHONE, CHEERS :)
luke....ah really...how come its just gone a bit mental and not stuck open or closed? Is that common? N ah thats cheap...ill get one from my motor factors then...what do i ask for as obv i doubt they'll have the glanzas reg number down?
Mech...how will i know if it is 76c? One thing ive noticed is its a bit indecisive like if i leave it parked it stays just under half....if i drive along then straight after off boost it will go back to cold? I heard most cars either stay just under half or fluctuate just above half in traffic and just under when driving?
The thermostat has stamped the temp on it....
Mine, with the stock 82c, it was just under half usualy
With the 76c, it like yours, half when standing, could reach even cold in highway...
Also, the stock gauge is not very reliable...
I've picked up a thermo from the motor factors today as the temp gauge is still a bit slow and fluctuating....also the heaters arent red hot so i'm gonna flush the matrix at the same time...
The new thermo is the 82oC stamped one, if my current one is 76oC will changing to the 82 one cause any problems?
