I bought this glanza in January 2010 and it was more or less completely standard apart from a backbox, air filter, dumpvalve, apex springs and wolfrace wheels. I wanted a good base to start with and the car was very clean as shown in the pics below:
The oil seals in the ct9 started to go so then I decided to go td04. This took me a few months to get the parts gathered up then the spec was as follows:
Toyosports mild steel manifold and decat
custom fmic
tomei fpr
blitz access ecu
td04L turbo
blitz dumpvalve
walbro fuel pump
optional front splitter + laguna splitter
Blue sparco fixed position bucket seats
16" rays replica wheels
mid duck spoiler
trd coilovers
rsr panhard rod
whiteline rear arb
The car made 207.3bhp at 0.9bar at steven scullions RR day.
I am now going to go down the forged route after alot of thinking on whether or not to sell up and get a ep3 type r or go forged. The car should be finished by January 2012. Heres a list of bits I've bought for the forged build:
74.5mm custom JE forged pistons
Scat rods
ACL bearings
ARP headstuds
1.4mm custom headgasket
Complete OEM toyota gasket kit
OEM oil pump
OEM water pump
Custom cams by Piper
zisco mild steel td04/td05 manifold, decat and screamer
38mm tial wastegate
AC competition clutch rated to 350bhp
vf35 turbo
Apexi Power FC with commander, harness and map sensor
3 gauge pilar pod with defi gauges
momo steering wheel
momo gearknob
indigalo dials
The engine is now removed from the car and is fully stripped ready for the machine work.
I have also removed inlet manifold and rocker cover for polishing. Then the block, strut brace, fuel rail and few other bits and pieces will be sprayed vauxhall arden blue. will get some pics up on sunday.
thanks lads hopefully everything will be finished around jan/feb as i want it to be perfect and then i'll have it ready to go for the spring and summer. zisco manifold, decat and screamer came this morning. love the look of the ram style manifold
