sosolid Posted November 16, 2011 Posted November 16, 2011 Ive got a standerd glanza which i want to increase the bost to 1 bar by putting a FCD. do i need to do anything else to it and can the turbo, intercooler handle 1 bar wit no mods. th turbo and intercooler r the standard one. Quote
N80Jamie Posted November 16, 2011 Posted November 16, 2011 You will need to do a fair bit of work before you can up the boost safely. DO NOT just get an FCD and up the boost because you will slowly destroy your engine and other components. Have a look at the 'tuning to 200bhp guide' that was done by a member called 'Socks'. Everything you need to know will be there Quote
N80Jamie Posted November 16, 2011 Posted November 16, 2011 Just realised the guide is on the UKSC domain so it cant be viewed at the minute. As soon as UKSC is back up heres the link to the guide: 200bhp guide Quote
akyakapotter Posted November 16, 2011 Posted November 16, 2011 need an exhaust fcd hks atuator fmic rrfpr oem ported mani or aftermarket one to safely run a bar of boost with out all that i really wouldnt up the boost mate unless you wanna kill your engine and once you have all that get it on a rr to check afr's :-) Quote
shaungt Posted November 16, 2011 Posted November 16, 2011 got a actuator for sale,fcd,if your intrestewd Quote
_shaun_ Posted November 16, 2011 Posted November 16, 2011 You will need to do a fair bit of work before you can up the boost safely. DO NOT just get an FCD and up the boost because you will slowly destroy your engine and other components. Have a look at the 'tuning to 200bhp guide' that was done by a member called 'Socks'. Everything you need to know will be there ^this the guide can currently be found here but once we go back to the uksc domain the link will change Quote
