had my new flywheel fitted the other day, and all seems ok apart from when im doordling along in 4th/5th and want to try and boost, it doesnt really go anywhere :S is this normal? would there be a loss in torque due to the lightness of the flywheel? im not sure
when boosting all the way through the gears its good and works perfectly, i.e revs increase/decrease quicker
does my problem sound normal??
the gauge and boost lights light up to where they should but the car doesnt go anywhere :S unless giving it full beans all through the gears
he checked the clutch and said it was mint, i had another one on order but as he said i didnt need it, i swapped it for the flywheel :S
lol, lazy fucker :) haha
the turbo seems to boost fine, like i said, if im boosting all the way through the gears all is good! its only when im tootling along in say 4th and want to boost then i have the problem :S
If you are in 4th i would of thought it would build up alot quicker with a lightened flywheel then a stock fly wheel as it takes longer to turn the crank!!..Do you not just think you are getting used to the power? lol..also are you runnig an hks actuator? that will help the boost come on abit quicker!
hmmm tricky 1,someone wil hav the answer.
u wernt hangin around with a fat cunt wer ya? lol
hahaha, i think she has a touch of the boost gremlins!!!
chuck it in 5th and floor it. if the clutch is slipping the revs will climb and the car wont go anywhere. dont suppose you have any pics of said clutch when it was out do you. also what clutch are you running :)
il have a little go on the way to work 2moro mate ;) its only a standard exedy clutch, but the thing is, before my car went in it was fine :S then had the quaife and flywheel fitted and its come back like this
when boosting from 1st to 5th mate its fine, revs quicker etc driving normally from 1st-3rd its fine, but as soon as i hit 4th put my foot on the accelerator slightly, boost on the gauge seems to build up and the car goes nowhere :S
this is my spec list so far aswell mate (just copy and pasted from ttgt lol) -
15" Enkie RP01's Painted Lamborghini Orange
Cusco Front Strut Brace
Cusco Rear Strut Brace
Baileys BOV
BC Racing BR Coilovers
Relocated HKS Mushroom Filter
Apexi cat-back exhaust
HKS Adjustable Actuator @ 0.75 bar
HDI Frount Mount
SPS De-cat
SPS Stainless Mani
Tong Turbo Hybrid ct9
HEL Braided Brake Lines
EBC Grooved Discs
Mintex Pads
Powerflex Engine & Gearbox Mounts
Fidanza Lightweight Flwheel
Quaife ATB LSD
