Hi guys
Recently got the GT a new turbo, KKK K26 With external waste gate. i think boost is below 1 bar.
Under high revs IE 4.000RPM the car starts to smoke... not alot but enough to see..
Now its just had a new HG changed... gone to metal 1.4mm and the Head was skimmed.
Engine was rebuilt.
Head, valve seals etc
Block... hones, rings, pistons
Around 5.000 MILES on rebuld.
What you rekon guys?
Just keep an eye on the smoke and check oil/ water levels frequently to see if they're dropping. Usually worn turbo oil seals will chuck out a load of smoke when your idling after a drive. That's what happened with my old hybrid ct9 anyway!
Might sound silly but are you sure its not just the cold weather + rain? I know due to my exhaust being angled up, every time it rains i get a pool of water in the backbox which creates white smoke for a good 10 minutes then clears up. Suppose that doesn't answer why your only getting smoke on high revs though.. Just keep an eye on your coolent levels mate.
ill take it out tomorrow for 10 mins or so... prob is cant really drive it... no insured or taxed...
anyone lend me a compression tester?
I had a kink in my breather pipe that caused mine to smoke
Really?... I'll take a look at that mate!
You know How the pipe made it smoke?
Not sure mate, prev owner done the work.
Can running to thin oil make the engine smoke ?
Im running the engine on cheap oil atm to flush it through!
think its 5w15 or 10w15
i know i normally use 5w40 on my toyotas
