scoobykilla Posted January 18, 2012 Posted January 18, 2012 Rite people, i have a few questions.Just removed my exhaust mani and had a small crack welded up, the mani is now back on the car and the car now sounds like a tractor( it sounds like its blowing from the bottom of the seal between the mani and cylinder head.TIME TO OWN UP I used the old gasket when putting the mani back on......is this the cause to my problem ???Next point, the manifold is a toyosport one so do i need to order a certain gasket or will a Genuine Toyota gasket do teh job ??And finally....What size are the 6 nuts holding the mani on ?? Thread aswell pleaseSorry for all the questions, this has been doing my head inThanks Quote
ro55ifumi Posted January 18, 2012 Posted January 18, 2012 Right first thing first, you answered the question with using the gasket again!!Pop in to your local dealer an order both the Genuine Gasket an bolts, will probs cost you £25 an you will be good to go!John Quote
MARC MOSS Posted January 18, 2012 Posted January 18, 2012 That and find a different manifold as well because it will crack again in the next couple of months I promise Quote
scoobykilla Posted January 18, 2012 Author Posted January 18, 2012 cheers john, so the OEM gasket will be fine for the Toyosport manifold ?Also is the gasket from the decat to exhaust (triangle shaped one) something i could get from a local car parts place ? Quote
ro55ifumi Posted January 18, 2012 Posted January 18, 2012 cheers john, so the OEM gasket will be fine for the Toyosport manifold ?Also is the gasket from the decat to exhaust (triangle shaped one) something i could get from a local car parts place ?Yes mate it will fit the Toyo manifold but as Mark has said it will go again!!Pop in your local Toyota dealer he does not bite an he will be able to sort you out gasket wise.John Quote
scoobykilla Posted January 18, 2012 Author Posted January 18, 2012 Ace, cheers lads. looking into new manifolds now but will have to wait till the bank balance rises a bit Quote
corofin12345 Posted January 18, 2012 Posted January 18, 2012 make sure to check the mani for warpage while its off too, handiest way is too put it up against a window Quote
