make the light come on, take it home, turn the ignition off one click to stop engine but keep ignition on so light doesnt get reset. Then bridge out the correct pins in the diagnostic box in the engine bay and count the flashes of the engine management light, the number of flashes indicates a code for a fault.
Check the fault number and hey presto :)
Craig
Will look into to a check up. Not really sure how its done but will have a look. Your helps great so at east I have a start. So I dont neef anthing to do a check on the fault code?
edit just found a guide!!!!
Edited by 206wasstarletpower
a paper clip mate bridge te1 and e1 on the little box by the fire wall under the bonnet on the battery side little black box with dignostics on it turn the ignition on and the eml light will flash a code will do the first bit say 3 flashes then the second part say 4 flashes so would be error code 34 if there is no faults it will flash non stop :-D
I had to install one for my turbo back exhaust (plus with the FCD I fitted a rrfpr for safety). The exhaust and decat caused boost creep, so depending on the weather it could hit it very easily
  • 2 weeks later...
