Put bluntly my brothers has just split, and mine just failed its mot on an excessively worn one, both less than a year old!!
Plus they dont actually properly bolt to the shock so you have to faff about with an adapter
Also has anyone got a spare front set of desent front brakelines??
the HEL ones use a small rubber sleeve similar to the ones on the ep70 youve pictured but they need ones like the ones on the ep82/91.
im wondering if they were fakes/knock off ones, as the place i got them is no longer open.
I dont supose you do your ep91 lines with a banjo fitting on the end??
We don't generally get into doing OEM replacement brake lines to be honest! Partly because we would be more expensive due to getting the best fit we can etc.
do you have coilovers, my originals have started to split with the miesters.....it seems the bracket isnt adjusted right so when turning it rubs/stretches ive played about to get it right but its not 100%
would take alot to mess a braided line up unless it was cheap to begin with....get onto HEL directly and see what they say dont mention the bracket thing tho
