Hi guys i fitted celica seats lately on my Glanza. This is a rough Guide....
Please read first before stripping your seat....At your own risk
Please Use Glanza rail.
Stripping
What you have to do is.....First
Strip the railing of the Celica seats
Strip the railing of the Glanza seats
Despose the railing of the celica.
Keep seat belt connector and the pole that go across the railing.
Keep the rail for the Glanza swap the pole that goes across the seat with the celica because the glanza is to short.
Fitting
Remember swap the pole that goes across the seat.......Despose Glanza pole is to short.
Passenger side
Connect the Celica seat to the Glanza railing 2 big bolts both side
Bottom cusion you can only fit 2 bolts....... passenger seat
Driver side
Two big bolts on both side
Bottom custion only one bolt unfortunalety.......Driver seat.......
Installing to the car
You can only fits three Bolts on both passenger and driver seat......
Thanks enjoy........your new seat
  • 1 year later...
All 4bolts can be fitted but the slide becomes a little stiff, no biggie but it just felt more solid to me! Get a mate to push the rail with a breaker bar towards the hole and then ratchet the bolt in quick time. Keeps MOT testers happy lol
Because you can only fit 2 bolts into the cushion used 3 self rappers at the front. The 4th bolt got 3 ideas. Cut and weld the subframe bracket. Drill down through the outrigger and drop a bolt in or drill the floor drop in a nut and weld it to captive it. Got to be done for MOT!!
You can actually get all 4 bolts attached to the cushion.
For the drivers, if you dremel the little nodules off the stop on the front two bolt holes, you can flip them and they line up with the holes in the cushion.
On the passenger side the front holes are static, so some strips of thick steel can be used to allow the brackets to reach the bolt holes.
