-20mm of your alloy wheel off set. e.g if your wheel was et35 it will now be the equivalent to et10
Would be ET15.... 35 - 20 = 15
to measure the offset you need to measure the width of the rim e.g 180mm now measure the distance from bolting face to the out side edge of the rim e.g 50mm now subtract that from half the width e.g 90-50 =40 and thats your off set et40. Of set is the measurement of the distance that the bolting face is off set from the centre of the rim. So a wheel with a 0 off set has its bolting flange at the centre of the wheel.
