right guys with td04 what have you done about the turbo oil return being a smaller diameter than the ct9 and therefor the rubber 90 bend not sealing on the return ????
im sure its 16mm to 19mm 90% bend ive been researching it sure some one will correct me if im wrong
any links for them buddy???? im sure ive seen some just run onto standard rubber but not sure how they've been sealed
i have supplied a few 90 silicone bends 19mm id hose suited for oil applications i can still supply these at a good price.
im also gonna be making the 19mm OD td04 return pipes for the tdo4, although i have never had a problem with fitting the
19mm id pipes to the standard td04 returns
