hi, i think there may be a problem with my clutch as sometimes when i put my clutch pedal right down the clutch isnt fully disengauged and is hard to take it out of gear, the car has a competition paddle clutch, any ideads what the problem could be?
thanks Stefan
there is a thread on toyotagtturbo saying there is a slight problem with the pressure plate catching the bell housing.
apparently it needs to be notched, dont know if that could be the problem.
It may just be that the pedal itself needs adjusted, I had to do this when I fitted my Blitz clutch. It's just a simple case of adjusting at the pedal - one luck nut to undo then raise or lower the engage point by adjusting the threaded rod.
