hi, i think there may be a problem with my clutch as sometimes when i put my clutch pedal right down the clutch isnt fully disengauged and is hard to take it out of gear, the car has a competition paddle clutch, any ideads what the problem could be?
thanks Stefan
It may just be that the pedal itself needs adjusted, I had to do this when I fitted my Blitz clutch. It's just a simple case of adjusting at the pedal - one luck nut to undo then raise or lower the engage point by adjusting the threaded rod.
