ali_legend Posted March 11, 2012 Posted March 11, 2012 Hi guys. In refurbing my rims soon. The centres are grey so should easily be able to sand down but the lip is chrome (pic below) How would I go about Sanding the lip down to spray onto. I will be spraying the centres Matt black and the lip candy red. Any tips on how to spray Matt black too, do I lacquer it etc? All tips would be much appreciated. Thanks Quote
206wasstarletpower Posted March 11, 2012 Posted March 11, 2012 Personally i would sand the outer lip of the rim back and then work my way up the grades of sandpaper. Say starting at 120 all the way thru to 2000 maybe 3000grit. Get that perfect polished lip. Quote
ali_legend Posted March 11, 2012 Author Posted March 11, 2012 So basically sand starting with 120 to 2000 and the. Primer and then candy red? And lacquer Also should I wet sand? Quote
Amjad Posted March 11, 2012 Posted March 11, 2012 I think he meant 2000 to get a polished lip, you don't want to go to such a high grade for painting I don't thinkAnd yeah definitely wet sand before primer and perhaps between coats? Quote
206wasstarletpower Posted March 11, 2012 Posted March 11, 2012 The lacquer wont stick to the polished lip as the lacquer need a rough surface to grab too. My old wheels on my yaris had a poilished outer lip and then had been lacquer and it just peeled off. I would do the rest of the wheel first ie paint and lacquer and do the polishing of the lip last. Looking at the pic again looks tight between the spoke and the polished part, might be a struggle to get the paper in between them??? Quote
lilryan Posted March 11, 2012 Posted March 11, 2012 samd the lip back with 120 180 grade mate then use a good high build primer then use a 800 wet and dry to wet flat the prime then degrease it paint and then clear coat mate that how i do rims at work remember 95% preb 5% paint bud Quote
206wasstarletpower Posted March 11, 2012 Posted March 11, 2012 (edited) arh lol mis read Edited March 11, 2012 by 206wasstarletpower Quote
akyakapotter Posted March 11, 2012 Posted March 11, 2012 hi there mate shouldnt be a problem to spraying onto chrome i did it on a set of lenzo RS5'5 that are currently sat in my garden like above just make sure you sand them down took me bloody ages done it on night shifts doing security lol :-D Quote
ali_legend Posted March 11, 2012 Author Posted March 11, 2012 Thanks guys for yor comments @lilryan- so I should wet sand the lip and the. Use a normal primer or hetch primer? And then sand again and then primer again? And then paint and laquer?@akyapotter- how did you go about doing it matey? A step by step guide would be bee e a utifull ;) lol Quote
Ryan-11 Posted March 11, 2012 Posted March 11, 2012 (edited) samd the lip back with 120 180 grade mate then use a good high build primer then use a 800 wet and dry to wet flat the prime then degrease it paint and then clear coat mate that how i do rims at work remember 95% preb 5% paint budThis ^^^^ but if your using rattle cans id rub the lip down alittle smoother than 180, maybe work your way to 400 grit. Edited March 11, 2012 by Ryan-11 Quote
ali_legend Posted March 11, 2012 Author Posted March 11, 2012 So how should I do the lip lol. Start with 180 and then go to 200 and then 600 then 800? Also the middle just sand using like say 800? Quote
Ryan-11 Posted March 11, 2012 Posted March 11, 2012 Id rub the whole wheel down with 400 grit including the lip use scotch brite on hard to get areas , any chips and scratches use some 180 then 240 then 400, etch prime any bear metal then prime the whole wheel, let it dry and rub down with 800 using water then paint and laquare. Quote
akyakapotter Posted March 11, 2012 Posted March 11, 2012 to be honist mate i just sanded like fuck put about 4 coats of primer on rubbed down about 4 coats of paint and about 4 coats of laquer thinking about puttung them on the V not sure set as i love my racin hart alloys i have on there at the moment Quote
ali_legend Posted March 11, 2012 Author Posted March 11, 2012 (edited) Thanks a lot guys. Should I wet sand all the time yh? Also what's scotch brite? Lol Edited March 11, 2012 by ali_legend Quote
