  • 3 weeks later...
i would also like to know whats the numbers represent ?
as far as i can work out simply is that less is more,
i.e the lower the number the less chance of hitting fuel cut so more boost is possible., so essentially number 12 is stock setting and anything lower is some form of fuel cut depending on supporting mods blah blah blah
obvously youd need a rrfpr to compliment this
but im around no 7 for a bar of boost with 45psi on rrfpr am running fine atm
but in all fairness should be set properly by a tuner which will be done shortly just a few more mods to go !!
hope this helps
Edited by russ78
The only thing the FCD is to lock the voltage so the fuel cut never cuts in, the only thing i can assume the dial does is adjust the voltage at which it locks. This is probably so it can be used on more than one car?
Get a pic up of it
Get a pic up of it
im not sure because i did have it on number 8 as was still hitting fuel cut every now and then maybe it changes the level that fuel cut is ?
hit fuel cut earlier at just over a ton today im thinking maybe its my rrfpr needs turning up as it was set 45psi with the vaccum off,
which seems to drop the psi a little when i put the vaccum back on ?
by the way sorry for hijacking your post matt lol
Edited by russ78
