ToyotaTech15 Posted March 22, 2012 Posted March 22, 2012 Here is a list of all changes to the MoT testing guide for 2012Additional reasons for rejection from 1st January 2012Lamps,reflectors and electrical equiptmentRegistration plate lamp(s) and the front and rear position lamps not illuminating with a single operation of the switchAll lamps, other than headlamps, having less than 50% of the light sources illuminatingAll lamps not being visible from a reasonable distance due to products on the light lens or sourceHazard warning lamps not fitted or inoperativeHeadlamp beam image is clearly incorrectSteering and SuspensionSteering and suspension ball joint dust covers not preventing the ingress of dirt etcAny inappropriate repair or modification to steering linkage, power steering or suspension componentsA steering lock stop missing where one was fitted as standardA significant oil leak from a steering boxPower steering: fluid level below minimum where visible; pipes and hoses damaged, corroded or fouling; components fouling or misaligned on external power steering systemsAny drive shaft support bearing excessively worn or a coupling gaiter missing or no longer preventing the ingress of dirt etc.BrakeA parking brake control missing or insecureAny inappropriate repair or modification to a parking or service brake control or a mechanical brake componentABS system component obviously missing, excessively damaged, inappropriately repaired or modifiedABS wiring excessively damagedA brake cable, rod or clevis joint insecureAny inappropriate repairs or modification to a braking system componentLoad sensing valve seized, inoperative, function impaired or incorrectly adjustedAir brake actuator dust cover missing or no longer preventing the ingress of dirt etc.Vehicle deviating excessively from a straight line during decelerometer parking brake efficiency check.Vehicle Structure, Body and General ItemsA drivers seat fore and aft adjustment mechanism not functioning as intendedA passenger door cannot be opened from outside the vehicle using relevant controlA door hinge, catch or pillar missing, insecure or deteriorated to the extent that the door cannot be readily opened or closedVehicle identification number incompleteA towbar assembly inappropriately repaired or modifiedExhaust ,Fuel and EmissionsA catalytic converter missing where one was fitted as standard (vehicles subject to a full cat test only)A fuel pipe or hose excessively chafed or damagedNew reasons from rejection from April/May 2012Lamps , reflectors and Electrical EquipmentHeadlamp levelling or cleaning device inoperative or obviously defective (LED or HiD headlamps only.)The 'Tell-tale' does not illuminate when main beam is selectedA battery insecure or leaking electrolyteelectrical wiring insecure or inadequately supported, or its insulation excessively damaged or deterioratedA trailer electrical socket insecure or damaged, or deteriorated to the extent that the connecting lead could not be securely connectedA trailer 13-pin Euro socket not operating the trailer lamps as intenedSteering and SuspensionA steering lock mechanism missing, inadvertently engaging or inoperativeAn electronic steering lock malfunction warning lamp displayedAn electronic power steering malfunction indicator lamp indicates a failure in the systemBrakesElectronic parking brake (EPB) warning indicates a malfunctionElectronic stability control (ESC) component obviously missing, excessively damaged or inappropriately repaired or modifiedESC Wiring excessively damagedESC warning lamp missing, not working or indicating a faultESC switch insecure or faultyA brake slack adjuster defective or incorrectly installedA brake fluid warning lamp illuminated or inoperativeTyresA tyre pressure monitoring system (TPMS) warning lamp inoperative or indicating a fault in the systemSeat Belts and Supplementary Restraint Systems (SRSs)An airbag mounting missing or seriously deteriorated resulting in excessive movementAn SRS malfunction indicator lamp operative on indicating a system malfunctionA seat belt load limiter or pre-tensioner missing or obviously deployedVehicle Structure, Body and General ItemsAn engine mounting missing or seriously deteriorated resulting in excessive movementAn engine mounting bracket missing, insecure, fractured or damaged so that it is likely to failA speedometer not fitted, cannot be illuminated, incomplete or dial glass broken or missing.Hope this helps with any confusion with new MoT rulesRegardsGary Quote
mattyD Posted March 22, 2012 Posted March 22, 2012 nice one mate clears things up no endthe only thing i have to worry about is not having a cat (but we know garages to get around that ;) )nothing on the noise of the exhaust system though? Quote
ToyotaTech15 Posted March 22, 2012 Author Posted March 22, 2012 It will only affect the car with the cat if they can prove it needs one etc, im away to look up emissions flow chart to try and point out which cars need cat test etc so everyone knows.There is already a fail on the MoT system for noise levels but doesnt state a reading etc so its down to the testers discretion. unless its crazy loud it should pass.Gary Quote
mattyD Posted March 22, 2012 Posted March 22, 2012 ok mate not to worry where i have been getting my M.O.T done, you give a little extra for there 'tea fund' and i think they bypass the whole cat situation and move on Quote
ToyotaTech15 Posted March 22, 2012 Author Posted March 22, 2012 Yeah thats handy i suppose, i have seen it before lol.Im sure people that are running big turbo kits arent going to swap back to a cat setup for mot then back againGary Quote
