A L 3 X Posted March 25, 2012 Posted March 25, 2012 I've noticed sometimes my handbrake doesn't hold, especially on steep hills, or takes a fair amount of clicks to get it to hold.I had a mechanic have a quick look and he said from the calipers it looks fine, they come to rest on the stops so are adjusting correctly and they pull on correctly, yet it doesn't hold for me, I asked if I should tighten it at the lever and all 3 at the garage said no it would make things worse, so what is the problem?Cheers Quote
micky boy Posted March 25, 2012 Posted March 25, 2012 There should be an adjuster on the handbrake its self! if you take the plastic surrounding off there should be a 10mm nut.. If you let your handbrake down then tighten the nut it should start feeling abit better! But dont go to mad because you could snap it. Quote
Idrees Posted March 25, 2012 Posted March 25, 2012 As above, adjust it from the 10mm nut to tighten up the cable Quote
The Toffinator Posted March 26, 2012 Posted March 26, 2012 Can you not adjust it on the calipers themselves? its always better to adjust them at the back than just winding the cable up. IF you can do it anyway:P Quote
morgey Posted March 26, 2012 Posted March 26, 2012 all I've ever heard is that the handbrakes suck on ep's with rear discs, mine do. if you want a decsent HB stick to drums lol Quote
Flaminsam Posted March 26, 2012 Posted March 26, 2012 agreed they have a pretty crap self adjusting mech inside them. ive stripped and re assembled about 6 calipers now and its the same thing every time. all i can say is make sure that the lever on the top of the caliper is returning fully. if it doesnt return fully then it cant adjust properly. dont touch the 10mm nut inside unless you have to. its only there to remove the slack from the cables not adjust them.il get some photos of the ones i have stripped at work when i can to explain how they work better. Quote
micky boy Posted March 26, 2012 Posted March 26, 2012 I've never adjusted the handbrake via the calipers!, not on any glanza i've owned anyway and never had any problems! Quote
A L 3 X Posted March 26, 2012 Author Posted March 26, 2012 Flaminsam, yeah my mechanic said its touching the stops correctly toAdjust itself? And he said not to adjust via the cabin like you said as it won't cure the problem?Unless of course my cable is stretched because it is touching the stops it just ain't holding well? Quote
