hoping to start of with 1.6bar on a td05 when engines forged to see what i can push but wonder what the limits of the arp headbolts are. and what would be involved if i went down the head stud route
im sure i remeber gaz sayin that if your going about 2 bar they will lift but with somethin like that id say better to be safe and go for 4age studs anyway.
russell
i had 1.6 bar on a td04 with standard headbolts and it was fine for 2years, ill soon be trying 1.8 bar with arp headbolts in. As for the head stud route u need your headbolt holes in the block drilled out and re tapped and your head bolt holes in the head drilled out.
