In the cars MOT (February) it got an advisory which was that one of the brake pipes was slightly corroded. Under the car the last day I had a look at it and it's very slight rust but rust nonetheless so to be safe I will just replace all of the copper pipes soon before I give the car a coat of waxoyl (currently not undersealed). I was just wondering how easy it would be to buy the copper pipe and a cutting tool + fittings and doing it myself? If not how many hours roughly would it take a garage to do it?
If you're replacing all the pipes youd be better using braided lines instead off copper pipes, its a good upgrade and doesn't cost much.
If you can do it yourself it doesn't take long because a garage will probably pull your pants down.
Yeah i'm going to change the rubber hoses to braided in the near future aswell but just concentrating on the copper ones just now as I have a daughter and need the car to be safe.
I have never touched a copper brake pipe before but if it's an easy job then I should be able to do it no bother. Could you give me a rough idea on what needs to be bought and how to do it.
I can do things like discs, pads, bleeding, suspension components, engine mounts, water pumps, exhaust components........etc pretty much anything as long as I have a rough idea how to do it and some extra time. But yeah may be easier and safer to just get my local mechanic to do it as he only charges £22 and hour.
Last year when I had my corsa this is what I would have done but now I have a half decent car and a child to carry in it I think I will go down the safer route and change them for peace of mind lol. How many hours work is in it roughly?
easy to change the pipes dude. i have a flaring tool, i ripped out all the hard lines, and made all new copper ones, running inside the car. practice a few times first before you make your proper lines.
you will make your money back on the tool and pipes etc by making lines up for your mates. defo a tool worth investing in!
To be brutally honest, if you dunno what your doing i wouldnt bother. You need to make the right style of flares and make sure there a good seal, then bleed the system properlly ect. How good are you with DIY mechanics ect.? Not a dig or anythibg but if you dont know anything technical wise i wouldnt risk it.
this should be noted as it is very good advise, :thumbsup:
back on topic tho i run full braided lines with the abs removed and it cost me about £250 to do,
