Amjad Posted April 17, 2012 Author Posted April 17, 2012 Yeah we cleaned the shiny face with brake cleaner Quote
Amjad Posted April 17, 2012 Author Posted April 17, 2012 Can anybody please confirm which way the release bearing sits? One of the side tabs is angled, and not square like the otherDoes it sit toward the back of the fork like this:Or toward the front (ie spun round 180 degrees)?Had a look at the new pressure plate, it seems as though some of the pucks are distorted. I haven't got anything to properly check but I ran a ruler and credit card over each plate (old and new) and it seemed to catch on a few pucks on the new one a bit. I'm guessing this was because the friction plate was fitted the wrong way the first time?Would the slightly distorted pucks of the pressure plate be to blame for the car not going into gear even when the friction disc was put in the right way?? Quote
Amjad Posted April 17, 2012 Author Posted April 17, 2012 I have yeah. Well for now I'm going to fit the old kit as I know that worked fine, it will help to rule out these bits so if the fault occurs again it's down to fitting or something like thatI may end up putting a new FE kit on later when I have the time, this flywheel may be dodgy or maybe it's just the clutch kit, I dunno! Quote
Amjad Posted April 17, 2012 Author Posted April 17, 2012 The bit where the clutch friction plate sticks out, is that the transmission or engine side? Quote
Idrees Posted April 17, 2012 Posted April 17, 2012 That side faces the gearbox, the flat side sits against the flywheel. Quote
Amjad Posted April 17, 2012 Author Posted April 17, 2012 Haha we had it right the first time! Flywheel or pressure plate is faulty, putting old kit back on now thanks Iddy! Quote
Amjad Posted April 21, 2012 Author Posted April 21, 2012 Turns out the pressure plate was probably at fault! The kit was bought from Camskill back in Jan, but inly fitted this weeks just gone. Do you guys think they would refund or exchange? Quote
Idrees Posted April 21, 2012 Posted April 21, 2012 I bought an Exedy from them, it severely failed within a few hundred miles and cost me a gearbox rebuild. They wouldn't refund it, but it's worth a try. Quote
Asad Posted April 21, 2012 Posted April 21, 2012 get a standard exedy amjad, never had a problem with them.....shame it was a blueprint one Quote
klyfax Posted April 22, 2012 Posted April 22, 2012 Next time, try adjust the clutch master cylinder. When you fitt a new clutch, the cylinder can be out of adjustment. Seen it some times here in Denmark with people fitting a new clutch on a older Toyota like a Starlet or Corolla...You adjust it where the clutch cylinder is linked with the clutch pedal. There you can adjust where the clutch should engage. Quote
Amjad Posted April 24, 2012 Author Posted April 24, 2012 Cool I may end up going with Exedy as I've heard of a few people having used them okay, never heard of Blueprint on FTEs I should have realised Thanks klyfax I'll give that a shot next time! Quote
