Billy SR Posted April 20, 2012 Posted April 20, 2012 I know this is a simple job in most peoples eyes, but i'm a complete novice with engines and if i'm gonna move on from n/a power in the future i don't want to be so don't laugh Basically my car has got to the point where it is religiously squeeling and very embarrasing. It's currently on 93k+ and the drive belt was last changed at 74, it appears to be in good condition, but has been tightened twice to it's maximum point in the past 10'000 (not by me)The second time it went back to normal after a day. I have both belts already to change, but i'm hoping it's not the alternator. If so i'll worry about it after changing the belts. Questions are, can someone tell me how to do it? what tools I will need? and ideally does anyone have any pictures? because i'm not so good with words half the time. Thankyou Quote
ryan lang Posted April 20, 2012 Posted April 20, 2012 if the alternator belt has been adjusted alot, it may be the adjuster thats coming loose, i know my mx5 was doing this alot recently and i had to put all new bolts in as they were shagged and kept rattling loose :/it is fairly easy though dude, as above, just have a good look at the bolts and figure out whats easiest for you to get to them etc, go make a cuppa, have a strategy planned, then get cracking just make sure you put the right belts on, the larger of the belts is the power steering i think.also dont forget to put the alternator belt around the water pump belt too fella as the alternator and water pump pulleys run from the same belt (closest to the engine) then the power steering belt goes out the smaller of the crank pulleys but it is the larger beltdont think i have any pics but if i had a starlet id take some for you lol Quote
ryan lang Posted April 20, 2012 Posted April 20, 2012 right i know the engine isnt in the car, and the power steering pump isnt actually attatched, but its all i have to work with the pink arrows are pointing to the main mounting point of the alternator and power steering pump - these need to be slackened 1stthe red arrows then point to the adjusters of each, these need to be slacked to remove the beltspower steering belt comes off 1st by undoing the threaded bar from the bottom (red arrow to the right of pic) (much easier with the bumper off) you then pivot the power steering pump downwards towards the engine. keep undoing the threaded bar until the belt is slack enough to come offonce that is removed, undo the adjuster bolt on the alternator and push the alternator in towards the engine until the belt is slack enough to come off (may need to be twisted to get it passed the engine mount)then repeat the process in reverse:alternator belt on 1st, making sure the belt is on the water pump pulley aswell as the alternator and crankpush alternator away from the engine to take up slack in the belttighten adjuster bolt (red arrow left of pic)tighten mounting bolt (pink arrow left of pic)(green is to show where the belt goes over the water pump)next power steering belt goes ontighten threaded bar until it pushes up the power steering pump (red arrow right of pic)belt should have around 1-1.5cm of movemement each way on the straight sectionsthen tighten up the mounting point (pink arrow right of pic)yellow is just to show where the belt goes hope that helps mateps. excuse the humungous torque wrench in the way :/ Quote
Billy SR Posted April 21, 2012 Author Posted April 21, 2012 amazing guys appreciate your time and effort going into writing this. gonna buy a new socket set next week as my rolson one is a load of utter shite, i don't suppose you could recommend a set? i already have a genuine power steering belt ready to go on, but the alternator belt i have to replace isn't 99364-20820 to remind myself ryan i don't suppose you know what bolts are needed exactly, toyota part numbers are a pain the arse. does the car need jacking up as the alternator belt is a pain the arse to reach from checking before? thanks very much anyway guys, just hoping this bloody rain clears over Quote
ryan lang Posted April 21, 2012 Posted April 21, 2012 yea its much easier to undo the mounting point on the alternator from underneath dudeurmm i think you'll need a 12mm spanner, 12mm socket, 14mm socket and a wratchet. you wont need new bolts dude Quote
Billy SR Posted April 21, 2012 Author Posted April 21, 2012 right splashed out on a tool chest today, hopefully i can get cracking at this tomorrow Quote
akyakapotter Posted April 21, 2012 Posted April 21, 2012 you check there were tools inside? haha Quote
Billy SR Posted April 22, 2012 Author Posted April 22, 2012 (edited) you check there were tools inside? haha, yeah, got a hydraulic jack for a tenner aswellcup of tea is being consumed right now Edited April 22, 2012 by Billy SR Quote
Billy SR Posted April 22, 2012 Author Posted April 22, 2012 no process so far. the tool kit stripped my bumper screw, the jack doesnt work and well it's now pissing it down.waaaah Quote
ryan lang Posted April 22, 2012 Posted April 22, 2012 whuttt!! where did you get the tools and jack from? Quote
Billy SR Posted April 22, 2012 Author Posted April 22, 2012 tools were an impulse buy from b&q, safe to say i will returning and the jack was from a carboot sale. poor student yay Quote
ryan lang Posted April 22, 2012 Posted April 22, 2012 lmao i know that one fella, luckily im studying vehicle maintenance and repair so i do alot of work on my car in college lol Quote
StuDoc 72 Posted April 25, 2012 Posted April 25, 2012 Buy halfords professional tools i think they are called halfords advanced now. Good if your on a budget and cant afford snap on but you get the same life time guaruntee. Chewing screws and bolts are just down to the wrong approach or wrong tool always check star screws are either philips or pozidrive invest in a can of WD40 along with your hammer and molies will be the best tools you own. Quote
