Kayble Posted May 2, 2012 Posted May 2, 2012 Ive been having 2 serious problems with my car since i bought it.The first is that it is overboosting wildly. The actuator is set at 10 psi, which it holds at up until 4k rpm, then it shoots up looking like its not going to stop rising. What could be the problem?The other problem is at low speed driving around town, the car hesitates then jerks when i lift my foot off the throttle and put it back on.Really need help with this as its pretty undriveable. Thanks Quote
Flaminsam Posted May 2, 2012 Posted May 2, 2012 First one sounds like boost creep. I'm guessing you have a free flow exhaust and a air filter. The second almost sounds like fuelling. So it could be either map sensor or the throttle position sensor. Quote
Amjad Posted May 2, 2012 Posted May 2, 2012 Is the clutch deffo not slipping? When mine was the revs jumped up without the car making much progress relative to revs Quote
*Zoe* Posted May 2, 2012 Posted May 2, 2012 time for a boost controller maybe, I've just had to get one as im pretty sure mine is spiking to Quote
rinseep82 Posted May 2, 2012 Posted May 2, 2012 sound like your fueling is all to cock get some managment dude or pop it back to stock boost fcd rrfpr maybe ?? Quote
Kayble Posted May 2, 2012 Author Posted May 2, 2012 Hey, i have a FMIC, FCD, Airfilter relocation, and decat+HKS exhaust, I have an HKS EVC4 boost controller, but ive unplugged it because it was doing nothing to stop the boost, i have the pipe straight from the compressor to actuator so i could see what actuator boost was.The clutch definitely isnt slipping, the car makes sore serious progress lol, but it looks like the boost will never stop climbing so ive never found out where it stops.Could the lurching be cured by an adjustable FPR, the car came with one but its not fitted. Quote
rinseep82 Posted May 2, 2012 Posted May 2, 2012 pop the fpr on and then go get it set up on some rollers should cure the problem i would think Quote
Kayble Posted May 2, 2012 Author Posted May 2, 2012 do you think it will cure the boosting problem, or just the lurching? Quote
Kayble Posted May 2, 2012 Author Posted May 2, 2012 the one between the compressor and actuator? Yes, have them nice and tight, are there any others i should check?Ive removed the EBC from the equation, so i know it wasnt that that was causing the problem Quote
Starbuck Posted May 2, 2012 Posted May 2, 2012 I only ask as my turbo had that infinite boost effect but it was due to having the the vac lines plumbed wrong. So you have no open vac pipes around the turbo etc? Get some images up. Quote
Kayble Posted May 2, 2012 Author Posted May 2, 2012 (edited) I tried taping up the airfilter but it had almost no effect whatsoeveralso totally disconnected the actuator from the wastegate, so it was constantly fully open. Car never made any boost at all (as expected) until 4k rpm where it when off the charts as usual Edited May 3, 2012 by Kayble Quote
Kayble Posted May 5, 2012 Author Posted May 5, 2012 So i ported the wastegate and took the car for a run. It still creeps but seems to stabilise at 14-16 psi Quote
