Idrees Posted May 2, 2012 Posted May 2, 2012 Yes, the bush size may be different so measure them before ordering new bushes, but yes they would fit. Quote
Amjad Posted May 2, 2012 Author Posted May 2, 2012 Which bush would it be? I currently have ALK and Whiteline ARB on there but I only need one wishbone changing Quote
Idrees Posted May 2, 2012 Posted May 2, 2012 The front bush, not the rear ALK bush. Why does the wishbone need changing? Quote
Amjad Posted May 2, 2012 Author Posted May 2, 2012 Grant had a look at the car today. It's knocking on left turns at about 30mph, we think the wishbone may be bent putting stress on the shaft hence the knocking. Further proof of this may include the fast that the alignment guy had to adjust max negative camber at the top mount to get it to only -1.2Would I be okay changing just that wishbone using the GT bush? I really don't want to have to pay for alignment and camber again on both sides because of changing two wishbones Quote
rob_bower Posted May 2, 2012 Posted May 2, 2012 The rear bush is different to isn't it due to the difference in the fixing one being 30mm and one being 350mm. Quote
Amjad Posted May 2, 2012 Author Posted May 2, 2012 I've no idea lol anyone else?I can easily get hold of one of these but getting an EP91 one will be tough so close to Japfest Quote
Amjad Posted May 2, 2012 Author Posted May 2, 2012 Driver side, not sure if I need a ball joint too Quote
Asad Posted May 3, 2012 Posted May 3, 2012 (edited) if your swaping the whole arms including bushes youll be fine (this WILL knock the alignment out)........why wasnt it knocking before you did the work on the clutch?, tbh if it was me id leave them for now......the bottom bolt is a fuck about once the captive nut breaks for freedom youve already had a headache with the clutch it will just cause you more upsetdid you check the top nut on the coilovers? Edited May 3, 2012 by Asad Quote
turbo Grant Posted May 3, 2012 Posted May 3, 2012 There is defo something not right with the o/f wish bone, hub/ball joint. If you look down the side of the car the wheels don't sit in the same place and if you look at the top mount the camber is as far neg as it can go. Quote
Idrees Posted May 3, 2012 Posted May 3, 2012 Did you inspect the ball joints? You can fit the GT wishbone without a problem but if you ever decide to poly bush the front wishbone bushes, you'll have to buy two different size bushes! Quote
Amjad Posted May 3, 2012 Author Posted May 3, 2012 Can't remember what Grant said about the ball joints?I wouldn't be wanting to polybush, just wanna know if it's okay and safe to use the wishbone on one side so different bushes either side? Quote
turbo Grant Posted May 3, 2012 Posted May 3, 2012 Ball joints looked ok no play. N/s boot was a bit split but the o/s was ok. have to try one of my wish bones on and see if that puts the wheel in the same place as the other side. If not then it can only leave you with a bent hub Quote
Amjad Posted May 3, 2012 Author Posted May 3, 2012 Hmm I've messaged Billy about the hub so see what he says!When are you free for me to pop down? Quote
Idrees Posted May 3, 2012 Posted May 3, 2012 If you fit the GT arm on it will be fine, the bush size doesn't affect the fitting to the car. If you don't want to pay for alignment again, use paint to mark to mark the exact location of the current lower arm and try your best to fit the new one in the exact same place. It won't be perfect, and ideally will need aligning again, but it's better than just slapping it on. Quote
Amjad Posted May 3, 2012 Author Posted May 3, 2012 Thanks for that, would rather not pay for alignment again since it just got done 2 weeks ago Thanks everyone for the help! Hopefully this sorts the knocking! Quote
Idrees Posted May 3, 2012 Posted May 3, 2012 You said you haven't fitted front poly bushes, have you inspected the original rubber bushes? Did you use a bar to check for play in the lower arm itself? A worn bush can cause a knocking too. Quote
Amjad Posted May 3, 2012 Author Posted May 3, 2012 We didn't no, Grant had a quick look over in a car park we didn't have any tools etc but we'll have a check!I didn't think it could be due to bushes but as he mentioned the wheel definitely does sit further out than on the passenger side Quote
Idrees Posted May 3, 2012 Posted May 3, 2012 If the bush is badly work then it would cause that, it could be a bent wishbone but that's also worth checking Quote
