KarlosOvCumbria Posted May 21, 2007 Posted May 21, 2007 Where abouts will the oil filter be on my ep91 1997 Glanza? Jacked her up yesterday and couldn't find it! need to know because' I'm changing it tomorrow, thanks Quote
jon5698 Posted May 21, 2007 Posted May 21, 2007 it is a bastard to get to mate, if you look under the car at the aircon pump at the bottom of the engine, it is on top of that. I loosened the aircon pump off to get better acces to it, that was till i binned the aircon. will only take about 30 mins now. Quote
KarlosOvCumbria Posted May 21, 2007 Author Posted May 21, 2007 Lurvly that'll do nicely mate cheers got some nice new oil for it too it's in desperate need for it! Quote
jon5698 Posted May 21, 2007 Posted May 21, 2007 nice one, if you undo the 4 bolts that hold the aircon pump on and take the belt off you can just let the pump hang to get access to the filter, it took me 3hrs the first time i done mine. Quote
shelly_star Posted May 21, 2007 Posted May 21, 2007 yeah tis a byatch to get to, even toyota dealer couldn't find it as i had to point it out to them when they gave my car back without a oil filter change hahahhaa, my dad found it in like 10mins. Quote
lobotomy Posted May 22, 2007 Posted May 22, 2007 The one that my car had on it when I first bought it was welded on -- took me about 4hours to just get the filter off! Now it's pretty easy because it's changed so often, I just squeeze my childish sized hands between the ac rad and my fmic ipe et voila, oil change in 10min. It is a bit awkward though as you can't prime the oil filter all the way up in case it spills everywhere trying to get it back on, but I just pull the EFI fuse and turn the car over a few times till the oil light on the dash goes off. Quote
nick gt turbo Posted May 23, 2007 Posted May 23, 2007 took the aircon off mine so theres loads of room to play with now! oil change is a piece of piss! highly recomend takin the air con off. saves alot of fuel to! Quote
RRR Posted July 13, 2007 Posted July 13, 2007 one of the hardest filters ive ever changed. Get rid of the a/con and it will be easy and you will gain a small bit of power also. there is a little guard around one side of the filter, get rid of it also wil make servicing easier in the future Quote
Ryno Posted July 13, 2007 Posted July 13, 2007 This might help -->CLICKY<-- (then say thanks to Jay) Quote
