Is there a coolant/water hose that goes into the back of the engine on a 4efte? Cars off the road at the moment as its leaking water :( need to source a new pipe
the main water pump hose runs along the back of the engine which goes to the thermo housing, then you have the small hose that comes out from the main water pipe which goes to the throttle body. then you have 2 for the heater matrix, (in and out) then you have the pipe that goes to the bottom of the rad
Really should take off my inlet manifold to get a better look and try identify this hose. At a guess I'm thinking it's the water pump hose
Anyone got a diagram that shows and labels each hose? Would be a great help
