RossTRD Posted May 7, 2012 Share Posted May 7, 2012 Is there a coolant/water hose that goes into the back of the engine on a 4efte? Cars off the road at the moment as its leaking water need to source a new pipe Quote Link to post Share on other sites
H_D Posted May 7, 2012 Share Posted May 7, 2012 Heater matrix hose it connects to the water pump. Quote Link to post Share on other sites
J25GTi Posted May 7, 2012 Share Posted May 7, 2012 all the water hoses go down the back of the engine? Water pump - stat hosing, all the heater pipes etc! Quote Link to post Share on other sites
AdamB Posted May 7, 2012 Share Posted May 7, 2012 On 5/7/2012 at 8:46 AM, J25GTi said: all the water hoses go down the back of the engine? Water pump - stat hosing, all the heater pipes etc!x2 Quote Link to post Share on other sites
ryan lang Posted May 7, 2012 Share Posted May 7, 2012 the main water pump hose runs along the back of the engine which goes to the thermo housing, then you have the small hose that comes out from the main water pipe which goes to the throttle body. then you have 2 for the heater matrix, (in and out) then you have the pipe that goes to the bottom of the rad Quote Link to post Share on other sites
RossTRD Posted May 7, 2012 Author Share Posted May 7, 2012 Really should take off my inlet manifold to get a better look and try identify this hose. At a guess I'm thinking it's the water pump hose Anyone got a diagram that shows and labels each hose? Would be a great help Quote Link to post Share on other sites
ryan lang Posted May 7, 2012 Share Posted May 7, 2012 if you can get a pic, ill happily label them for you with the inlet manifold off, everything is easily visible Quote Link to post Share on other sites
RossTRD Posted May 7, 2012 Author Share Posted May 7, 2012 That'll be a good help thanks!Will take a pic tomorro Quote Link to post Share on other sites
