ashley1 Posted May 7, 2012 Share Posted May 7, 2012 hey I've recently fitted a td04 kit and tried fitting my hks adjustable actuator but i am having trouble fitting it and keeping the boost up i put it on the other day and it showed 0.2 bar boost how do i sort this Quote Link to post Share on other sites
5T4R7ET N/A Posted May 7, 2012 Share Posted May 7, 2012 what bracket are you using to hold the actuator? it has to be pretty strong, because the tension from the actuator spring goes on the bracket. Quote Link to post Share on other sites
ashley1 Posted May 7, 2012 Author Share Posted May 7, 2012 it is the bracket that came with the hks actuator just re drilled a new hole to meet the td04 hole hopefully this will work Quote Link to post Share on other sites
DavidAshton Posted May 7, 2012 Share Posted May 7, 2012 You need to post a picture of how you have it setup. It could be anything but a picture will help us work out where you are going wrong. Quote Link to post Share on other sites
ashley1 Posted May 8, 2012 Author Share Posted May 8, 2012 ok once it is fitted i will post it ok Quote Link to post Share on other sites
