Banbury Glanza Posted May 16, 2012 Posted May 16, 2012 My interior light does not work, I have tried the simple things like new bulb and fuse ect. But I have the foot well lighting and ignition barrel lighting and they work fine any ideas why the interior doesn't work ?? Cheers Todd Quote
Ste B Posted May 16, 2012 Posted May 16, 2012 Could be a bad earth on it mate. One of the screws holding it into the roof is what earths it. Could be contacts on the light either, you'll see where the little arm slide across a load of contacts. Give the contacts a rub down with some sandpaper if they look a bit corroded. Quote
LukeSR Posted May 16, 2012 Posted May 16, 2012 Check out http://www.ukstarletclub.com/forums/index.php?showtopic=53221&hl= mate Quote
*Zoe* Posted May 16, 2012 Posted May 16, 2012 mine did this was dodgy wireing, i had a button sensor put in my door and the wiring sorted so now it works was a cheap job but had it done by a garage Quote
Banbury Glanza Posted May 16, 2012 Author Posted May 16, 2012 LukeSR the link doesn't work :/ I will try the sand paper cheers all Quote
