maddox710 Posted May 16, 2012 Posted May 16, 2012 Hi guys, need abit of advice here.When im pulling up at juntion or slowing down to stop (5mph) its sounds like the abs pump making a gunny farting noise, also the brake pedal kicks back as it does it. Only does this as slow speeds though, any clues ? Quote
pick1 Posted May 17, 2012 Posted May 17, 2012 I know this is a different care but I had an f1 Megane sport that used to do it and it turned out the wires going into the abs sensor in the hub had come slightly loose so was messing it up and causing it to turn on off play up etc italy be something similar mate just a thought Quote
BoGlE Posted May 17, 2012 Posted May 17, 2012 could have a cracked abs ring(or very rusty) The sensor will only pick the crack up at slow speeds. Quote
5T4R7ET N/A Posted May 18, 2012 Posted May 18, 2012 probably its the ABS sensors that are playing up or some connection gone loose.if its the sensors then you can bypass them, but it means running with no abs. but who needs abs, rip it out and shed some weight Quote
maddox710 Posted May 18, 2012 Author Posted May 18, 2012 cheers guy, will take the wheels of at the weekend and have a good look and get back too yall Quote
