Weyro Posted May 21, 2012 Share Posted May 21, 2012 Going to do a compression test on the Glanza V. What pressure should it be achieving on each piston? Cheers Quote Link to post Share on other sites
Starbuck Posted May 21, 2012 Share Posted May 21, 2012 it will vary fella. But a reading of around 150-160 across all 4 and you're in the right area of good. Quote Link to post Share on other sites
Socks Posted May 21, 2012 Share Posted May 21, 2012 If engine was up to running temp ^^Generally your not looking at the amount of pressure...Your looking at differences between the cylinders! Quote Link to post Share on other sites
Weyro Posted May 21, 2012 Author Share Posted May 21, 2012 OK cool, hopefully all is well. Just doing a health check Quote Link to post Share on other sites
Flaminsam Posted May 22, 2012 Share Posted May 22, 2012 There should be no more than a bar difference across all 4 cylinders. I did one on mine and got around 150-160psi across all 4. Quote Link to post Share on other sites
